When trying to start any cycle nf appears on timer
NF stands for no fill, which means you are not getting any water into the machine. This is either because the water valve has failed or is clogged, the water is turned off or the pressure switch thinks there is already water in the machine but the last is very unlikely.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Hello
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
