Televison & Video Logo
Stephen Seaton Posted on Jun 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony kdf e50 12u wont turn on red light blinks twice
Red light blinks twice and wont turn on
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Jun 22, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
32119
Points
233
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Oct 30, 2009
SOURCE: I have a KDF-E50A12U Sony TV it won't turn on and
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Anonymous
  • 81 Answers
  • Posted on Apr 22, 2010
SOURCE: Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Anonymous
  • Posted on Jan 07, 2009
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Anonymous
  • Posted on Sep 29, 2009
SOURCE: Sony KDF-55WF655 won't turn on, red light blinks 6 times
Replace the lamp. It easy to do.
Anonymous
  • 10594 Answers
  • Posted on Nov 14, 2009
SOURCE: sony kdf-42e2000 tv red light blinks 3 times
3 blink error shows that lamp cover is not fixed properly after lamp replacement.
Please check Lamp Cover and put it back properly.
Sony kdfe50a12u red light flashes twice and wont turn on.
Go to this website for blinking codes. Also you can bring the onscreen diagnosis test up by pushing on your remote set, 5, volume- and power. Make sure the tv is off when doing this. http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
2helpful
3answers
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
4helpful
I have a KDF-E50A12U Sony TV it won't turn on and keeps Flashing red twice, no other lights are on, just the stand by continually flashing twice.
2helpful
2answers
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Sony wega kdf-50e2000 standdby light blinks 8 times
8 BLINKS B -10.5 IS OVER VOLTAGE (B-BOARD) If your a novice call Sony or a Sony authorized service center.
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Tv blinks 6 red blinks
Thermal Fuse kit needs replacement = part # 1-910-023-93
Qualified tech only.....T.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
