Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Posted on Dec 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I ahve a Kenmore Elite side by side refrigerator with watre and ice on the front and freezer below..there is a message Er IF on the dispaly and it will not make ice..this unit is 1 1/2 yrs old..the freezer is good and the frige works..any suggestions?
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 25, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033454
Points
35540
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore Refrigerator reads a code on door ER IF how do I clear this code out and what does it mean?
IF fault code usually for ice maker fan motor. Check in the freezer on left side beside ice maker
4helpful
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
4helpful
Er if message and no ice being made. Help! kenmore elite stainless steal...can't get water either! and no information in owner's manuel about error codes?
1helpful
Kenmore elite french doors bottom freezer Model # 795.77573600. There is an message Er FF and is very noisy.
Well you got a kenmore that i believe is actually made by either Samsung, or LG, since Kenmore does not make any refrigerators, they are ALL taken from other name brands with the name kenmore put on the front. I would start by looking at your owners manual for troublshooting codes, but chances are you have a faulty evaporator fan motor, either the motor itsself is out of balance, or possibly ice is obstructing fan blade, and you'll need to find the source of that problem instead. hope this helps
www.FixMyFridge.net
We have the kenmore elite trio bottom freezer refrigerator model 795.7756 - we have error message ER IF, we know the ice maker will not come on and have tried resetting it. How can we get the icemaker to...
3helpful
My kenmore elite bottom freezer unit displays an "er IF" message and water is leaking from the ice maker door. what does this mean? the manual doesn't help
2helpful
2answers
MY ICE MAKER WON'T WORK
2answers
Kenmore Elite Bottom Freezer Refrigerator Model #795.77562600 Serial #608KR00238 The control pad is locked up, it dispalys Er CO. You can't change from water, ice to crushed ice. The ice maker runs. It...
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
