The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
SOURCE: LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
SOURCE: scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
SOURCE: My Cannon Lide 90 only scans one document. try to
Check your hard drive space and system RAM requirements. Often this happens because there is not enough "Scratch Pad" space..OR RAM these days 4GB is too small sometimes.
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
