Main water line seems to have adequate pressure on nearby sinks and with the kitchen sink spray hose. Faucet has a hot and cold tap and both have low pressure. Filter screen on faucet is clean and clear. Pressure seems to increase when we use the spray hose. Pressure off main spout may be slightly increased but drops gradually after spray hose is turned off.
Your problem is a simple one.
Problem solved.
I have the same problem with my Price Pfister Marielle Kitchen Faucet. Did this work?
I had the same problem with my Price Pfister Marielle faucet and I replace the diverter (pn 951-039) and that did the trick. The faucet is working like new! Thank you.
I have the same problem with the pfister marielle, bunches have the same problem, becareful with the recommeded solutions.
1. 951-039 is the plastic diverter and will not work if you have a brass diverter. part# (brass) 951-029 (call price pfister to make sure.)
2. this could also be the cartridge, 974-035.
the aggravating thing is that you can find similar parts local, but there are no translation from suppliers part number to the manufacturer and nothing on the packaging otherwise specifying. lame. in short, call price pfister and moan about this expensive good for nothing faucet that has parts have to purchase through them.
ridiculous. never buying price pfister again.
when filling sink the handle slowly goes down and water stops unless I hold handle up
