Vizio VW42LF 42 in. LCD HDTV Logo
Posted on Jul 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio start blue/yellow flickering screen
I was moving today-my TV was lying down on it's back in the sun for about an hour (87 degrees today). After getting to our new place, I plugged it in & the screen flickers blue, then blue with yellow/white1/2 & 1/2. I can't get to the normal blue screen or any normal picture for that matter. I've unplugged the HDMI/Cable from the TV. Otherwise, it turns on just fine-just seems like the picture is blown?
  • krismatyas
    krismatyas Jul 02, 2012
    To add a little: the blue standby screen is scrambled... Large yellow flickering blocks appear, and lots of lines going every which way. I can't see anything-tried switching to diff inputs. They're all the same
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Jul 01, 2017
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003382
Points
237762
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
4 Related Answers
Anonymous
  • 56 Answers
  • Posted on May 12, 2009
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Anonymous
  • 1139 Answers
  • Posted on Jun 14, 2009
SOURCE: SV470XVT Vizio picture freezes
Hello, This seems more like an interface problem then a board issue. Which interface are you using Component Video, HDMI or , RF(F Connector)? If you are using the RF (F Connector) there might be a problem in the tuner including the RF and IF sections on the circuit board. If you are using HDMI there might be a problem in the HDMI Integrated Circuit If you are using componente video the there might be a problem in the video circuits connected to the RCA jacks of the Component video input. If I were you I would have the take the TV back to the shop and have these items checked out, because board swapping is not the proper thing to do. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Anonymous
  • 13 Answers
  • Posted on Jan 22, 2010
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Anonymous
  • 18 Answers
  • Posted on Mar 01, 2011
SOURCE: I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
My Vizio m55-d0 TV keeps flickering between completely red, blue, white,black and green screens.
Try to turn the TV off and on by removing the power plug. Leave the plug out for at least one hour and then try again.
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
My 70" Vizio smart TV will turn on but there is no picture or sound. I think it blew a fuse.. how do I fix it??
the first thing i would do id completely disconnect power to vizio tv and wait roughly two mins before plugging it back it. once that is done try to see if your picture comes back up . if your screen does not comes back the tv has unfortunately taken a turn for the worst. sometimes it costs more to repair than it does to replace so just make sure that your tv is or is not covered under a manufacturers warranty that may be able to have to tv replace for free depending on the scenario. below is the number and hours of operation. i also gave you a link to their support site. good luck!
Thank you for visiting VIZIO Support Hours: Monday - Friday 7 a.m. - 9 p.m. CST
Sat & Sun 9 a.m. - 6 p.m.
Toll-Free Number: 855-833-3221 Official VIZIO Support
3helpful
3answers
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,
First of all, thank you for posting your question here at Fixya.
Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.
If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.
Hope I helped you.
Have a nice day!
Good luck and take care!
Jdvillanueva
I purchased a Vizio 32' VA320M off of ebay and it arrived today, I hooked it up watched it for a couple hours this morning, played a little xbox on it and went to sleep. I woke up tonight and was...
This tv have the main Tuner signal board have intermitten problems.Return this tv for a refund.Can't return it make a claim with Ebay,Pay PAL or ur credit card if pay by credit cards.
Vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
Vizio vx37l green/red/blue sparkles
Call Vizio tech support and start a case. i am having the same issues with mine and i have sent it back. they will be replacing it this time.
2helpful
3answers
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
