Make sure that modem is connected to the linksys, and cords are properly seated.
if cords are seated correctly, hard wire computer to linksys first.
second, access the linksys software thru 192.168.1.1 on the address bar on internet explorer browser.
third,if you will see pop-up box asking for username and password.username must be left blank and password must be set to admin.
forth,inside the linksys software try to access wireless settings.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
NOTE : For WRP400, the default IP address would be
"192.168.15.1" and if you place the router behind a primary router with
the IP address of "192.168.15.1", then the router will automatically
assume a new default IP address, "192.168.16.1".
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
