SOURCE: Delete Button on Kodak Easyshare CX7530 doesn't work
I had same problem. I opened up camera and simply move the back of the delete button around a bit to ensure the button would hit the contact when pressed. Closed the camera back up and it now works fine. I have dropped the camera a number of times I think the button and the contact became misaligned.
SOURCE: I have a Kodak dx4530. Recently, when I push the
The camera is not recommending the picture, It could be overexposed, shaky or taken in the wrong SCN.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera. The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
SOURCE: my Kodak EasyShare DX4530 zoom digital camera does
no image formation,may be shutter/ccd.Chaque both,replace the defective.
SOURCE: Flash just doesn't work on Kodak Easyshare
When you were having that lens problem, did you perchance open the camera case to repair it? If so, please see this link, and afterwards verify that all outer case screws are present and firmly seated (but don't strip them).
1 In any Still mode, press the Menu button.
2 Press to highlight Exposure Compensation , then press the OK
button.
3 Press to select the Exposure
Compensation setting.
If pictures are too light, decrease the
value.
If pictures are too dark, increase the
value.
4 Press the OK button to accept the change.
5 Press the Menu button to exit the menu.
6 Use the camera screen to frame your
subject. Press the Shutter button half-way
to set the focus, then continue pressing
completely down to take the picture.
This setting remains until you change the
Mode dial or turn off the camera.
here is the link for the manual if the details are not clear http://www.retrevo.com/d/ds/progress?doc=9f1ccaf06b7e8ecedf71c821d3c1fb02&rk=0.5443618496384233
