Hotpoint Aquarius WF220 Front Load Washer Logo
Posted on Oct 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint Aquarius WF220 won't power on
My Hotpoint Aquarius WF220 refuses to power on. This happend about a month ago, I unplugged it, left it for half an hour and when I tried again it was fine - until now. I've had no other problems with it at all, and am reluctant to call out an engineer without trying a few fixes first. It's only 3 years old.
Thanks
  • 1 more comment
  • everitdf Dec 04, 2008
    Hi, the model I have doesn't have an electronic display. There is a programme selection dial, then a series of buttons (such as rinse hold and the power button) that have an LED next to them.
    Hope that helps.
  • tony_carpent Dec 31, 2008
    exactly the same problem ?
  • Anonymous May 11, 2010
    Does it show any error message on the display?
Gerry Harvey
Level 3:
Genius:
  • Hotpoint Master 1,482 Answers
  • Posted on Oct 21, 2017
Gerry Harvey
Hotpoint Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379098
Points
4533
Could be the plug itself, or door interlock switch, try cutting off plug replacing Interlock cost is around 20GBP.
5 Related Answers
Carl Harries
  • 11 Answers
  • Posted on Feb 18, 2007
SOURCE: Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
douglas smith
  • 1462 Answers
  • Posted on Jul 05, 2008
SOURCE: hotpoint aquarius wma56
probably due to not draining.
there is a filter in the system which you need to remove and clean. possible also that you have a foreign object jamming the pump.
take the back panel at the bottom of the machine off.
you will see a large diameter hose going from the bottom of the tub to the pump.remove this hose at the tub end. lots of water will come out so make sure none goes on the motor. the filter is inside this hose. take out and clean
let me know if this doesn't work
Anonymous
  • 86 Answers
  • Posted on Dec 28, 2008
SOURCE: Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Anonymous
  • 86 Answers
  • Posted on Dec 30, 2008
SOURCE: hotpoint aquarius washing machine water
Hi, Ok first things first where is your machines waste pipe connected? If it connected to the sink trap check there first by undoing it and check that there is nothing inside stopping it from letting the water out..?
If this is clear then have you lost anything? Sock? ETC....? Can you hear the pump? And is the water draining but not spinning?
If you cannot hear the pump running then it will more that likely be the pump as they are a magnetic pump which fail quite alot. If the pump is running then it is going to be something you have lost which will be located in the sump hose underneath the machine whic comes from the tub to the pump. Take it off and check and clean as nesscerary. Or last but not least it could be the fact it is doing everything but not spinning ( no drum action )? Check the motor carbon brushes if they are low then this will cause the problem or the motor has failed!....
Good luck and let me know ho you get on??
Anonymous
  • 100 Answers
  • Posted on Feb 03, 2009
SOURCE: Hotpoint Aquarius WF220 Front Load Washer dirty rubber drum seal
its a matter of removing the front retaining wire and the inner one which holds it onto the drum, an easy enough job to get off, sometimes a pain to get the inner off and on depending whether it s the screw or clamp type , screw=easy. to get the clamp off use a screwdriver to wiggle the bent wire out of the ratchet grooves. to put back is done with long nose pliers, preferably bent nose ones.
Toplight flasing withstart light on hotpoint wf220
check door interlock, may be faulty.
Unplug the washer before checking!
1helpful
Hotpoint aquarius banging about when spinning
hi take the top of the machine and check the brick at top or bottom of the machine they sometimes come lose .
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
3helpful
Aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
1helpful
Operating instructions
Hello.
I can help you with your query.
In your browser bar type in hotpoint user manuals
In the drop down list, click on
manuals-user guides-handbooks-hotpoint service
In the search box enter your model number and download the instructions.
Please rate my fixya solution.
Thankyou
2answers
Hotpoint wf220 glass door
undo door hinge from cabinet - held with two screws.
the door halves are held togethet with a few screws which undo and the door will split apart so you can replace the glass
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
