Question about Fuji FinePix F10 Digital Camera
Set the timer on my finepix f10 and it does not do anything?
  • 31 Answers
Once the timer is set, then you need to press the button to take photo, once you do that the camera will count down and take the photo. Good luck.
Posted on Jan 05, 2009
6ya staff
SOURCE:
Hello, I have bought an adapter micro sd xd adapter for an old finepix f10 photo camera. I have tried more micro sd card 2GB, 4GB, 8GB with this new adapter, but is is not working in my finepix f10. It...
Your Finepix F10 does not support SDHC (High Capacity) memory cards.
You can only use standard SD cards with a maximum capacity of 2GB.
New technics are not always backwards compatible, sorry for that.
Jul 21, 2011 | Cameras
I have a Fujifilm Finepix S5200. Need to know if there's an option to set a 2 second timer PERMANENTLY, and not have to set the 2 second timer every time i take one picture. Thanks -Leo
Nnteen,
I'm sorry, but I don't believe that can be done. The settings for the timer should clear after you power cycle the camera. The timer is not the default setting, so it reverts.
Thank you.
Mar 23, 2011 | Fuji FinePix S5200 / S5600 Digital Camera
Setting the timer
Press the 4-way switch downwards to cycle through the selftimer modes: First press shows the selftimer symbol, which means 10 secs delay, next press shows selftimer2 symbol, which gives 2 secs delay. When delay is set, press the shutter button to take the picture. The selftimer lamp will blink untill the picture is taken.
Jul 08, 2010 | Fuji FinePix F10 Digital Camera
Camera is in japanese or chinese language and we need to change it to english.
go into the setup menu ("set") by pressing the menu button, and look for the picture of a little man yelling (he's speaking). That's the language set-up. Set it for english.
The self-timer is accessed through the arrow dial. The little picture of the clock at the bottom of the dial is the timer setting. The camera must be in the shooting mode to use the timer, not in playback. Here's a link to the owner's manual http://www.fujifilm.ca/x3717.xml
May 21, 2009 | Fuji FinePix F10 Digital Camera
Camera will not connect with PC to download pictures
Hi I am vortash .. check for damage on your download lead and around the camera plug interface .. check that the drivers are still installed and reinstall them to make sure ... if you have a sd card installed remove it as it may be lose in the socket and the camera is trying to read it and can't .. check your batteries are ok .. try it on another computer .. if all this fails sounds like the camera interface has broken constant plugging in and out can sometimes cause problems with a loose plug .. hope tthis helps Regards Vortash
May 04, 2009 | Fuji FinePix F10 Digital Camera
My photos are always blotchy and unclear
I had the same issue mate, I found that because this camera is ISO1600 i had set ISO800 in the automatic mode. Yes! in automatic mode you can still change the ISO ratings, I had set it to 800 which screwed all my photos.
Now i have set it to Auto and the camera is back to its excellent form.
I know F10 was sold as ISO1600 camera and most users tried to use highest ISO and failed.
Its an excellent camera just dont use high iso
Aug 22, 2008 | Fuji FinePix F10 Digital Camera
Lost manual -set timer
Hi , In self timer is found in function set /press function set ,navigate the knob to drive mode , navigate knob to 10 seconds , click the shooter of camera then then okey.
Dec 24, 2007 | Fuji FinePix S3000 Digital Camera
Finepix f10 problem
Plug came off the wall? What do you mean by this, the plug to what exactly the charger? How is the charger camera battery set up? Where is the red light on the charger? More detail please
May 10, 2007 | Fuji FinePix F10 Digital Camera
Fuji FinePix F10 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Ekse
Azam Ali
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
