My portable dvd player cannot read and play disc anymore it is less than a month old, it was working well at first i played several disc on it ,after some days it was rejecting some disc and finally it stopped reading and playing discs
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4
1. Make sure that the disc is not dirty or scratched. Try
to clean the disc.
2. Check the ribbon for any dirt or broken connector or
try to change it with a new one.
3.
Check the player was properly upgraded according to the CD that was
using.
4. Check the motor and lens, try to the clean the lens
or replace it with a new one.
5.
Try to restore the default settings and factory settings with the remote
control.
6.
Check for proper
voltage in mainboard and power supply especially the +5volts.
7.
Check for any
bloated capacitor in the power supply or mainboard
8.
Check the servo
IC or replace it.
I hope it helps!!!
Rating Locked! (?) bettyeze has rated this solution as Not Rated
