Originally polaris was not getting out of deep end. Purchased drive belts but pool guy says unit runs on hydraulics not belts. Unit was working after his repair of putting new treads on tires. Suffered a water leak at booster pump, drain plug shot out, drain plug re installed, now wheels are not turning. No filter assembly to check near wall of pool for the 380. Just have two sets of swivels near wall.
If your Pol wheel sometimes stops turning and you could force it half a turn to make it go again. Chances are that you have the same problem as mine: HAIR GETS AROUND THE AXIL OF THE DRIVE WHEEL.
This can be fixed by first removing the wheel cap with a flat head screwdriver, then remove the retaining clip that holds the wheel in place. (Be careful not to lose the clip!). Remove the wheel and remove the hair around the axil. Put things back in reverse order. You are set.
SOURCE: polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
SOURCE: 2004 Polaris 500 ATV. Changed water pump Now it leaks out weep hole. Any answers
The new pump shaft seal is no good. Get another pump.
