If you are talking about videos that you shot with the iPad, if you did not backup the iPad or sync with iTunes before you lost them, they are gone. If you mean purchased movies - you may be able to dwonload them again in the purchased tab of iTunes - if you live in the U.S. and - if those particular movies are available for re downloding. You need to use the same Apple ID that you bought them with.
And there is a step-by-step tutorial about how to Recover Deleted Files on iPad, which can help you recover deleted videos from iPad.
Although you can not see those deleted videos, they are still in your iPad. Even without iTunes backup files, you can use iPad data recovery software to directly recover lost videos from the iPad device. Read more here: http://www.ipaddatarecovery.org/ Best regards!
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
SOURCE: Deleted video on iPad 2 by accident
Do you live in the United States? If you do then you can download them again for free - as long as the movies are available for free downloads. Apple has not forged agreements with every movie studio yet so you just have to check.
Launch iTunes, and tap on the purchased tab. In the upper left corner you will see a "View" button. Tap that in order to toggle among music, TV Shows and Movies. Select Movies and then see if the movies appear. If they do, tap the Movie icon and then tap the cloud icon next to the icon in order to begin the download.
You have to use the same Apple ID that you used to purchase them.
If you do not live in the U.S. then you will have to purchase them again.
Besides, I do like to share you another tutorial recovery deleted video from iPad 2, hope it can help you.
SOURCE: How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Firstly you have to plug your iPad into Computer and open a iTunes .
After that you can locate a iPad on the left side of the screen and click to the "device" menu .
Then right click on the name of iPad and click to the recover files and select a summary option which is inside a dialog box .
After that place a check mark next to the "Encrypt iPad Backup".
Now you have to enter a password and click to the set Password .
Then plug your iPad into Computer and choose a 'edit" option .
Now you can recover deleted files from Apple iPad.
when you deleted your videos of iPad, you should know that they are still intact in somewhere of your iPad, but you have no access to them unless you have an iPad Data Recovery software to help you scan and extract them, only in this way can you recover your lost videos of iPad.
