I know my xbox doesn't have any problem , because I tested my xbox with the same HDMI cable to my samsung LCD TV and I havent any noise problem even with the same headphone. I dont know what the problem is, maybe all of the LG E2260 series have the same problem with audio output ( no noise on 100% brightness, having noise on 99% or less) or maybe my rooms power plugs has issue!!! I dont know why, is anyone has a solution for me? thanks
SOURCE: Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
SOURCE: Using different speakers for TV
If it does not have anything besides optical it will not work unless you have a system capable of optical input (some Logitechs have it, but don't remember which ones, i know that the Z-5500 does certainly have it but that's not too cheap).
Weird that it doesn't have a a headphone jack indeed. But if it doesn't, that optical digital out is the only way to connect it.
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
SOURCE: problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
SOURCE: to play laptop thru samsung tv
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
*my headphone going have some noise like buzzing!!
