Como resetear error f5-02 de una toshiba studio 162d
SOURCE: program mode
l have a error code H-2-00 on e studio 162d how should get into program mode to reset it?
SOURCE: error code H2-00 on e studio 162d?
u have a dirty thirmistor in fusr unit.first clean it.then do this procedure.press clear key,auto photo key,clear,auto photo key in a sequence.copier will go dead .when display goes dead just press 14 start key.copier will take few second and will bi ok.by MIAN AKHLAQ
SOURCE: How do you reset Admin on a Toshiba e-studio 162D
In the manual it says to "Turn on power while holding down the status button on the network expansion kit. Continue to hold down the status button until a beep sounds."
It looks like the default password was TOSHIBA which took me forever to find. The user name should just be admin.
SOURCE: The error indicator is staying lit constantly on Toshiba e-studio
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
SOURCE: manual de partes de la copiadora toshiba e-studio 35
visita esta pagina www.gioffice/op_manual tal vez les ayude en algo, yo busco el manual dee partes de Toshiba e282, si alguien lo tiene se lo encargo... mi direccion dianali96arrobahotmail.com saludos y gracias
