Right size belt, just a bear to put on. Easiest way, zip tie belt to fly wheel (one each side of spoke/spine). Than run belt around pulley on motor, turn fly wheel, helps to guide belt as you turn. Takes a lil force but not much. Than slowly turn fly wheel to center belt. Be sure the ribs of belt are in troffs of pulley, if not easily pushed over, about 1 inch from pulley.
the timer motor on the timer that advances the timer is defective,replace the entire timer as a motor for the timer will be just as much as a timer if its available separatelyanyway
I don't have a solution, I have the same PROBLEM! This is ridiculous! I bought mine in April 2009. So obviously its out of the 1 yr limited warranty status! So now what?!?!
The part number for the model you have listed is WH08X10036. I found your washer listed at pcappliancerepair.com, with a complete illustrated parts breakdown. Other sites you may try are:
Dump in a gallon of white vinegar, fill with water, highest setting, after it goes through that setting, turn it off and let it set in the washer for about 30 minutes (use hot water).
Then put it on another wash cycle and then go to the rinse and spin. This should remove the order, and you should leave the door open when not in use.
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
