Question about Panasonic Lumix DMC-TZ1 Digital Camera
I have a Panasonic DMC-TZ1 that I can't get the flash to go off on. The only flash setting that works on my camera is no flash setting and the icon for the no flash symbol appears white. The rest of the settings such as automatic flash with red-eye, and automatic flash, ect... are red. Is this a settings issues or a repair issue? If it is a repair issue could you tell me what on the camera needs to be repaired. Weather it be the LED light is broken or a resistor or transistor on the circuit board that needs to be changed. I believe I can fix the problem myself if I knew where to begin. I can't find any blogs or questions about this problems fix on the web. Can you help me
6ya staff
SOURCE:
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Repairing Circuit Board
Q553 is a mosfet transistor NTE2973 ,caps1200pf 2k volts c552 is probly good, you might also have to replace STK-392-110s if so you will have to do complete convergence alinement. you need someone who knows how to solder,and do set up alinement for this does have to be done by someone who knows how if not done correctly you can shut set down,then you will really have trouble!!!!!!
Posted on Dec 23, 2007
otacon
Damen Wong
  • 1950 Answers
SOURCE: I own a Panasonic Lumix DMC-TZ1
Are you taking pics on auto mode or manual?
Posted on Dec 26, 2007
Anonymous
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Posted on Jan 03, 2008
johnychel
isaac johny
  • 796 Answers
SOURCE: Where can I send my camera for repair
hello
Posted on Feb 25, 2008
Jrussell789
  • 172 Answers
SOURCE: Flash problems fix Panasonic DMC-TZ1
There is a Force Flash setting on this camera I believe. Force Flash means Always Flash(on). If this does not work, then flash is burned out I would guess.
The TZ1 has been replaced by the smaller, newer and nicer wide angle TZ3 and latest TZ5. Consider selling you defect TZ1 to a repair person on ebay, and buy you a good used, refurb, or new TZ3 or 5. Prices are very good, and your is worth about $25 to $30 with all accessories that came with it.
Posted on Feb 27, 2009
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
How to turn the flash off DMC-TZ1 camera?
On the menu set button at the bottom right at the back of the camera, if you press the right hand side of this you can change the way the flash operates from auto, auto/red-eye reduction, forced on... and the final one would be forced off. You can download the manual from http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_222458 enter DMC-TZ1 into the enter model box and then download the operating instructions and on page 40 it will show you how to do it.
Jan 25, 2012 | Panasonic Cameras
Hi bi currently have a Problem with my Panasonic Lumix DMC-TZ50 Digital Camera the Flash seems to have stopped working? any clues how i can fix it and will it cost much? Regards Pete
The flash of my Panasonic DMC-TZ1 camera has stopped working normally - it flashes but the image is dummy. Could it be its falshing lamp is reaching its recources after working 3 years? Can it be changed?
Jan 28, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
What is the highest capacity memory card that I can use in my Panasonic DMC-TZ1?
Assuming you're using SD cards, they top out at 2GB. Cards larger than 2GB are SDHC and they will not work in the DMC-TZ1. So, you may use SD cards up to 2GB in size.
Jun 29, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
My Panasonic DMC-TZ1 camera wont print pictures with the date on it... Does anyone who has this model know what i am doing wrong here?
Well you have to go to your menu and change your camera settings. Hope this helps!?
Please rate solution - Thanks.
Apr 19, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
How do you turn the flash off so I can take pictures where a flash cannot be used?
Press Right on the cursor button (marked with the lightning bolt icon) to switch the flash setting. Your choices are AUTO, AUTO/Red-eye reduction, Forced ON, Forced ON/Red-eye reduction, Slow sync/Red-eye reduction, and Forced OFF.
Multiple copies of pictures
Yes may be, there was a same query here;
Check the settings for "Burst Mode" in your Cam, it will be under main settings menu. Turn it off, if the problem prevails better backup all the pics/videos and then Reset the Camera.
If helpfull, kindly do Rank.
Regards,
Waqar
Jul 17, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Dec 05, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Flash doesn't work right
first step would be to reset the camera in the setup menu - reset settings and setup parameters - turn camera off for about 15 seconds then back on and take a snapshot in simple mode (heart icon) on the mode dial. If the picture turns out problematic it could be a flash or image sensor issue - if it comes out fine then it was an issue before with the settings - possibly the ISO sensitivity.
Mar 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
48 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
