Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
My washing machine is stuck on pause mode. When I push any button or turn the wash cycle knob I get beeps and an error message that flashes PAU & ERR. I have tried all the solutions listed on this site. I have also tried every conceivable combination of buttons to unlock the control panel, unplugged the machine overnight and checked the connections on the door to make sure they are catching properly - all to no avail. Please help!
  • 6 more comments
  • Andrew Erbelding Feb 12, 2007
    Catriver,
    Thank you for the help. I unplugged the washer for 30 seconds, plugged it back in, held down the Start/Pause and Cancel buttons together and the same error message comes up (Err). The machine is blinking 57 and PAU when no buttons are held down. I think 57 is the last wash setting we used and I'm assuming PAU means Pause.
    Any ideas?
  • Andrew Erbelding Feb 16, 2007
    catriver - thank you for your help - luckily the washer is still under warranty and electrolux sent out a repair tech who determined the control panel had broken. This is covered under the warranty, so they are replacing it. Thank you for your assistance is attempting to help me!
  • Anonymous Dec 17, 2007
    Same problem--using your method to determine error code, I got error code E47.
  • Anonymous Dec 26, 2007
    PAU code
  • laurababes Feb 29, 2008
    i get an error message and its stuck on pause. I am unable to get a number. a few months ago the repair tech unplugged something and it was just fine.. any suggestions
  • Anonymous Jan 10, 2009
    Any idea what error code ESE means?
  • Rastamis
    Rastamis Dec 15, 2013
    Mr PJ Fixit - You just saved us a major headache too, THANK YOU
  • Raul Queue
    Raul Queue Jan 16, 2014
    My retared inlaws were visiting and would over load the machine and it would rattle out of balance. Once one of the support feet got loose and had to reconnect it because the plastic screw got loose. one year later it started pausing thanks to them inlaws visiting. it seems the after praying lubricant Silicon between the pulley wheel and the drum it started spinning faster. it seems as if it might have to do with too much friction at that location. I get no error code except the pause. I cleaned and reset the door switch and still keeps pausing.
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Posted on Jan 10, 2009
  • 11 more comments
  • Gumby10 Nov 16, 2010
    Sir,
    I do not know you but would like to extend a great big hand shake your way. Your advice on resetting the door latch was spot on!!!!! I just had called Frigidaire and they were very little help, they advised me to use the option / select reset soloution. Of course the option from Frigidaire did not work. Once I used your solution the washer worked fine. Thanks for saving me 200.00 in repairs. If ever we meet the first beer is on me.
  • mmedina7 Feb 22, 2011
    OMG this worked! My Frigidaire ATF6000ES1 washer was stuck on an ERR PAUSE message and I did the above, very easy and it reset! THANKS A BUNCH...
    Meg
  • musafir Oct 18, 2012
    Hi MR .P J Fixit... I tried the steps mentioned by you. However, the washer is still stuck on pause. Can you please suggest what to do to fix this ? Thanks a lot. Appreciate your help. - musafir
    Hello Mr P J Fixit... I performed the steps mentioned by you. However, the washer is still stuck on pause. Can you please suggest the next steps to fix this issue ? Thanks.
  • Buddy Lewis Jan 14, 2013
    How do you remove the outer ring that holds the seal on?
    How do you remove the outer ring you mentioned?
  • Nia Guido May 31, 2013
    Can someone please help? I have err E41 and would like to try the steps given above. How do you remove the outer ring that holds the seal on? Thanks
  • kevin
    kevin Oct 28, 2013
    i watched the first minute of this youtube video and was able to remove and reinstall the outer sealhttps://www.youtube.com/watch?v=OPmNtO-Q... thanks to mr. pj fixit for this great solution though
  • Nathiam
    Nathiam Nov 01, 2013
    Mr PJ Fixit's solution totally worked. Thanks, man!!
  • Rastamis
    Thanks for saving us a major headache. THANK YOU!
  • GMax
    GMax Jan 06, 2014
    Mr. PJ Fixit. Thank you very much. Your solution saved us time and money. The error in my washer was "err pau 18h". Just a recommendation for others trying...make sure your washer is plugged and error displayed while doing the procedure so the reset can take place.
  • edward_bo58774
    edward_bo58774 Feb 03, 2014
    Did this. Yes, it took only 5 mis, and so far so good. Thank you!!
  • Alvin Marin
    Alvin Marin Jun 18, 2014
    I wish I would have seen this prior to buying a motor control board and the latch assembly. I knew it was wasn't a normal code because it didn't have an E with the number 57. Funny thing is my buddy is a repairman and told me that 57 was the error code. He must have failed the Frigidaire repair coarse. Now I have some extra parts that hopefully I won't need anytime soon.
    President:
  • 878 Answers
Aerb, unplug the washer for 30 seconds and plug it back in. With in five seconds press and hold the start/pause and cancel buttons together. As long as these buttons are held in you should get the error code. The code should appear as an E followed by two numbers, a number and a letter or two letters. We need to find out what the actual error is. If this works, post back with the code. Catriver.
Posted on Feb 11, 2007
  • 2 more comments
  • Ron Marek
    Ron Marek Feb 13, 2007
    aerb, If the error code is a 57, that could be a problem with the motor control board or motor itself. E57 means a high current on the inverter. Here is what you have to check. Remove the belt from the motor and spin the motor pulley. If it does not spin, the motor is the problem. Spin the tub pulley, does it spin free? If not it may be the tub bearings. Remove the harness from the motor and measure the resistance between pins 1&2 1&3 and 2&3. All the readings should be between 4 to 6 ohms.If the readings are good, replace the speed control board. If the readings are incorrect replace the motor. Parts can get expensive so the tests must be made. This is for an e57 code. Catriver...post back.
    that doesn't work for me. No error code, just stuck on Err and PAU
  • Phil Grubb Apr 21, 2013
    When I did that it gave me "E41". This is the second time it has done this. The first time it just started working on its own. Very aggravating. Any suggestions? Sounds like you really know what you are talking about. Thanks
  • Vicky maggiore Aug 20, 2013
    I got "E41" too, what do I have to do?
    New Friend:
THANK YOU SO MUCH MR.PJ FIXIT! You saved my sanity tonight!! Your solution worked after a service man told me I would have to shell out a few hundred bucks for a control panel. Again, thank you!! YOU ROCK!
Posted on Apr 06, 2010
  • Nathiam
    I echo that!! Thank you Mr PJ Fixit... Worked like a charm!!! You DO rock!!!
I did the above and got a code of dr. My washer model number is GLTF2070DS0. the first code I got when the machine went down was PAU.
Posted on Dec 23, 2007
    New Friend:
I did everything and the pause button is still lit. what do i do? my washer wont work because the pause button. PLEASE HELP!!!!
Posted on May 26, 2012
Mr PJ Fix IT- I just had to thank you SOOO much for all of your help. We have had this washer for about 4yrs now, it's a piece of junk. I'd have paid for it three times over if I had to call a repair man everytime something went wrong. I swear I get the E20 every six weeks. Tonight it locked up in pause, and you helped us fix it!!! Thanks soooo much for your help!!! You are a life saver!!!!
Posted on Jun 18, 2010
We have a frigidaire washer ATF6000ESO. Our machine was flashing ERR then PAU then 33 and wouldn't do anything else. A service call determined that is was saying that it was in the pause mode and had 33 minutes left on a "quick cycle"and he determined that the door latch/switch was faulty and that caused the machine to think the door was open. Needless to say a new latch/switch fixed it!
Posted on Dec 28, 2007
What does the DR code mean?
Posted on Jun 27, 2009
Anonymous
SOURCE:
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Our frigidaire front loading washer keeps pausing in cycle and it isn't finishing its final spin. If you have any suggestions I would be greatful.
Same for us,,,
We have to turn the dial and try to put it back approximately at the same place on the dial
(turning clokwise 360 degrees)
Sorry this is the best solution I could find
Jun 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Machine stuck on pause/err
un plug the washer for 5 minutes and re try
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Pause Error - Frigidaire Affinity LTF6000ES0
If you just paused the washer and now displays a error try draining any existing water all out of the machine.Before re filling it see if you still get the error message.I'll be happy to guide you through this.
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
17,338 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
