Reset the internet tablet and needed to dl the latest version of appslib . The version that it came with is obviously out of date. It loads the old version without any issue but i cant load anything other than the update for the latest appslib. when i dl the newer appslib it tells me it is not compatible with my device...?
SOURCE: setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
SOURCE: tablet pc drops wireless connection randomly
Fujitsu Lifebook N3010 WiFi Wireless Card CP024081 ... $29.99 - E-Tech eShop Fujitsu Lifebook N3510 B Wireless Card Cp024120-02 $10.99 - eBay
SOURCE: I bought a coby tablet
It might be the version of the Android on it. If you use Android 2.1, then you have to upgrade it to Android 2.2, then you will be able to play Flashcontent.
But bad news is, that you have to wait, until Coby releases an Android 2.2 upgrade for Kyros (http://www.androidtablets.net/forum/coby-tablets/3663-coby-kyros-7015-tablet-questions.html), because if you upgrade your tablet PC from elsewhere, then it might be malfunctioning.
SOURCE: the disgo 6000 tablet i cant load anything on to
Hello darling, Please put the Disgo 6000 update on at www.mydisgo.info/archives/1655 Try using the wifi to get apps and wigets straight to the machine, use the advance button next to the on button on the back of the device while in wifi settings to set any ip or dns settings. It works chucky egg as my self and son have cracked it, slightly fiddly though. My rough **** daughter who brakes everything can even use it without loosing her temper. Its ok by cherub dave
SOURCE: I got a coby tablet MID7015 and I don't have the code to unlock it.
If your device is in USB Debugging mode, your adb server may be in some wierd state on your computer. From the command prompt (from the \android-sdk-windows\tools folder), type adb kill-server and press enter. Then type adb start-server and press enter.
Hopefully this will help!
