http://www.simplefta.com/attachment.php?attachmentid=9826&d=1381762350
Well you've to signUp at this forum in order to Download a firmware for your openbox
Registration is Simple , So after Registering
Download the file from above link and
Updated
Openbox All-in-One Clone Safe For_ s9_s10_s11_s12
Openbox update (updated a lot of channels Updated
Openbox s9..s10..s11.. s12.. all-in-one file 10-14-13
This is complete .abs file with channel list i made with newer firmware......
Satellite is set using a diseqc switch with 119
Satellite set to port 1 and 110
Satellite on port 2 ( you may have to adjust your
Satellite settings to match your system )and using the free trial japan server (japan server is down now so you must put your own p$ info in to get a picture)........Follow these steps.....Download this file to desktop and then unzip it and send the (.abs file)to your usb pen drive---then take from computer and insert in your
Openbox---now go to menu----tools---upgrade by usb---top line is upgrade mode ( set this to ''image file(.abs)" )---now one click down to upgrade file and right click to find this file ( .abs )---then one click down to "start" (ok) and let it download and when it asks "are you sure to burn" click "yes" and let it finish and reboot...........If you get scrolling picture when you downloaded just hit the v-format button on your remote until the picture straightens out and go to ....Menu---system setup---down to ''video out'' and set that on ''rgb''........Exit out to picture......This file is the latest upgrade with channel list included and will work fine on S9..S10..S11..S12
Openbox receivers......If you have trouble updating with USB just use the serial loader and a null modem cable.........................bigslim
there are no details it is what it is
