You Need to Try One Of The Following :
Remove and re-install Imaging Unit (make sure that Imaging Unit
is locked in place). Turn the printer off, then on.
Replace Imaging Unit (make sure that Imaging Unit is locked in
If problem persists for Error 30, clean the sensor.
If problem persists, check www2.tek.com/merlin/tko and/or
contact Service.
Here's the User Manual to Follow if you need it :-)
Open the imaging unit. Clean the rubber coated rollers with petrol. Grease the ball bearings, clean the waist toner and the re-assemble it.
