The dishwasher worked fine until I had to level it to fit under our new cabinets. After a long search I found a picture of the sensor, in the lower front right corner of the dishwasher. When I leveled the dishwasher, I raised the back first and I am concerned that I have gotten water in the sensor or need to dry it out.
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom.
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working.
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
SOURCE: Low water level error with
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
SOURCE: i have a samsung dmt300
I would remove and examine the wash arms to see if any of the holes are plugged with food or mineral deposits. Clear any food with a paper clip. If you have mineral deposits, remove the deposits with Lime Away or CLR cleaner. Hope this helps you.
SOURCE: I have a DMT300rfw samsung dishwasher. The other
I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
SOURCE: samsung dishwasher crackling popping sound
Try http://www.manualowl.com
for FREE PDF and perhaps you can troubleshoot problem yourself.
Best of luck with your frustrating issue. I empathize, shampayn20.Jimmy
Testimonial: "Thank you. I will try this and see what happens. I'm running out of patience with this particular appliance :)"
