Washer machine will stay in one cycle and continue to operate without automatcially changing cycles
SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
SOURCE: washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
SOURCE: washing machine error code on Frigidaire ATF6000E
My Affinity washer gives E 36 and E68. E68 says test 14 just what is test 14.
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
The unit's timer and control board are either both faulty or miscommunicating with each other.
