Time saver keeps flashing don't know how stop it and I can't open door
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
SOURCE: I've recently bought a Hoover
turn the wash temperature control knob anticlockwise until you come to the key symbol at the end of the blue zone; then turn the knob a little further and the door will swing open; a special safety device prevents thedoor from opening during the wash or at the end of the spin cycle; at the end of the spin wait up to two minutes before opening the door - the instructions from the user's manual. good luck!
