Can't get the back off the watch
SOURCE: Pulsar battery replacement
There is either a little lip around the edge of the back plate, or there is 5 notches around the back plate, If a lip use a sharp knife and put in the notch and twist upward, the back should either come off or move in that derection. Now if you cant see a lip, use a razor blade and in betwen the casing and the back plate insert the razor and with a hammer tap LIGHTLY it should come off or move in that derection, and then use a knife to pry off, If it has the notches, use a needle nose pliers and put in the two notches that are farthest apart and turn counter-clockwise. If you are still having problems please let me kno. I will be glad to assist you further. Good Luck!!
SOURCE: I recently got a Pulsar
Im a watch technician for how many years and when iv'e make adjustment to any new watch for me i dont need any manual. The thing iv'e done is keep pushing and pressing the adjustment button and observed what happen and the result i write it down, what im discover new to me for future setting purposes. When setting a Pulsar chronograph watch you just find the set button and press it for 15 seconds , then your watch display will flashing then go to mode button and choose what you are going to set. the Hour ; the Date ; the Alarm and whatever you going to set is there. The operation to set is desame whatever you going to set it's like a cycle. Only the set is need a long press. feel free for further assistance in keep sending more question in comments or doubts that arise your mind regarding this to me,.rate the solution as fixya if it heps you understand in solve your problem.
SOURCE: I didn't receive an instruction manual
The store where I bought the watch called Pulsar direct and they are sending me an instruction manual.
SOURCE: How to set alarm on Pulsar Chronograph 100M
See PDF here to solve this problem.
Wish Pulsar would have included this info with their watches!
http://www.pulsarwatches.com.au/manuals_pdf/121_1.pdf
SOURCE: how to set alarm on
Here is a link to find instructions:
http://www.pulsarwatches.com/home2.asp#FAQ
