You can hear the computer running it acts like it's going to boot up then breifly showes the blue hp screen then goes blank, you can still hear it running..What is wrong with it ? How do I fix it?
I'm having the same problem. blue hp logo then goes dark. I hear the windows start sound. but still black screen. If i let it sit overnight it comes up fine. when i shut it off and start it again nothing. I updated the vid driver when it was up but no change.. Gave the customer a loaner. I'm sure heat has something to do with it. but i'm opening it up in the morning.
You best bet is to pull the hard drive and attach it to another computer. This will allow you to copy the infomation you are worried about to another sorce. Most computer retailers that offer services will have a back up service and can do this for you. The average cost in my area for a back is $100.
Once you have the computer repaired, make sure you back things up. If you are worried about loosing something back it up twice. External hard drives are reasonably priced, and most computer have some kind of optical burner.
Hope this helps
SOURCE: Hp TouchSmart 310 wont start,power light flashes
The LED light has now turned into a diagnostic light. The fault is a bad Power Supply.
Replacing it however, is easier said than done.
I don't know what exact model of the Touchsmart 310 series you have.
(Examples such as TouchSmart 310-1000Z, or 310-1125f, or 310-1155y, etc.)
The TouchSmart 310 series of All-In-One desktop computers, has a battery, and an AC adapter, (Charger), for power.
Test the battery with a multimeter set to DC Voltage.
{Symbol is a dotted line over a solid line. If there is more than one DC Voltage setting, set it to 0 - 50 Volts }
Should be close to 18.5 Volts (DC)
Battery is low?
Check the AC adapter (Charger)
The middle metal cylinder of the plug that goes into the computer, is Positive.
The outside metal shell which surrounds it, is Negative.
Again, 18.5 Volts (DC)
Check both then post back in a Comment.
Regards,
joecoolvette
SOURCE: WRONG CONFIGURATION/BLACK SCREEN/HP PAVILION a810n
if it is in warranty i would suggest you to call the hp guys .... if out of waranty please post the exact error message
SOURCE: Screen problem with HP DV 9000
I think Your computer C.P.U. power supply unit is not working properly. because these type of problem occur when Power Supply Unit is not working properly.........
So Don't afraid at all just change your c.p.u. power supply unit with new one (it is not costly at all).
SOURCE: HP Pavilion a1610n will not boot up. I get the
If you have tried another monitor and result is the same, then it's a faulty graphics card.
If graphics card is sharing system memory, then you might need to replace ram to get it work again.
SOURCE: HP TouchSmart IQ770 PC Desktop replace screen
Hi ,
I have pasted the url so kindly copy paste it in the address bar and you will find the moving pictures .All u need to do is just roll the mouse over the picture and u will find something interesting ....It gives u the steps to replace the screen...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01060928&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3351220
hope this will help u .....all the best...
hope this helps you
It is under warrenty, but they told me on the phone that I will lose all data on the computer, I have tons of pictures of my childern on there and I don't want to lose them, any suggestions on how to get it to turn back on for a few to drag and drop them on a flash drive?
I can't try another monitor it's a ALL IN ONE. It's a HP TOUCHSMART.
