Geneva Chronograph Look Watch Logo
Posted on Jun 28, 2012
How do I set a Geneva platinum watch? - Geneva Chronograph Look Watch
1 Related Answer
Anonymous
  • Posted on Dec 10, 2008
SOURCE: geneva watch bracelet
I Have a Geneva Made Pga Tour Partners Club watch that needs a new band and I have not been able to find one.It is a special band and the PGA partners club says they are no longer available and were not helpful in finding a band.
1helpful
Looking for Game Time Schedule Watch Montreal Canadiens replacement strap. Are they available?
Hello -
The Game Time Schedule Watches are manufactured and sold by the Geneva Watch Group.
I have not yet found any replacement straps for sale online for the Montreal Canadiens version of the watch.
Therefore, I suggest you contact the Geneva Watch Group Customer Service department to ask about the availability of a replacement watch strap:
Email:
[email protected]
Best wishes.
Apr 20, 2018 • Watches
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
How to I set the day on my Geneva watch model on612-m
keep pushing buttons till something changes.Usually you hold a button down for 3 secs then things start flashing,then you forward it to the time section
1helpful
I cant figure out how to set my new watchs' date i tried to see if there is a difference with how far you pull the stem out to try and set it that way and i also tried spinning it around in a 24 hour cycle...
There is probably a screw that is lose on the watch. Someone will need to pop open the caseback and make sure the screws are in place. If you or someone can't figure it out I suggest taking it to a watch repair person, do not go to a high end place they will charge more then what the watch is worth. Go to watch repair shop , and if they charge more then $10.00 then it's better just to buy a new watch on ebay.
How do i set my Geneva Japan Movt 257 Watch?
You pop the 'crown' out (dial) then turn it till correct time, then push it back in. It's on E-how, depending on the type of watch, or how many dials it has, the directions may change.
Link: http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Nov 28, 2010 • Watches
Geneva watch bracelet
Top Geneva Watches Experts
john h
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Geneva Watch Expert? Answer questions, earn points and help others
