I went to the link you provided and it says my device doesn't support adobe flash player. Am I doing something wrongI went to the link you provided and it says my device doesn't support adobe flash player. Am I doing something wrong
You can't post conmments that contain an email address.
Make sure your talbet is OFF the do the following PRESS Power on & Volume button TOGETHER once the writing appears let go of the buttons . If that doesn't sort the problem go to YOU TUBE type in your question and a Video should appear showing you what you have do the solve your problem . Make sure you have tablet to hand and you can go through it with the video .
This can be the result of you internet speed to the device (computer, laptop, ipad, kindle, etc.). Even if you have a relatively fast connection to your home - if others are using bandwidth - less is available to *you*. Wireless signals can cause speeds to vary significantly - depending on the distance from the wifi router, the number and type of obstacles between and their composition (brick, wall board, steel, etc.). Try watching when standing 10 feet from the router and with no one else using the connection (no streaming music, video, downloading, etc.). If you're working - start walking further away until it breaks up. This would be your maximum distance - under optimal conditions. As more people use the internet connection at your home - the less will be available to you - requiring you to move closer to the wifi router. If you're having trouble with videos even with no one else around, you may have a problem with your speed. You should run a speed test on the system by going to a wired internet connected computer and going to the speed test site below. Let the test run without doing other things on the computer or network. Check the results against the level of service / speed your provider says they are selling you and work with them to clear up any issues.
Do you have a friend with a name brand tablet that could come over and test if your wifi can handle streaming? If another tablet gets the same results as your tablet it could be a issue with your wifi access point. I don't use Netflix anymore but can you confirm your new tablet has enough processing power to stream video? Can you stream youtube HD videos?
Did you allow the battery to run down until it was completely drained?
- If so then try the following;
Watch this video (link below). You should only remove the back cover, disconnect and reconnect battery cable. Disregard the rest of the video as I could not find one doing ONLY what you would need to do. Follow the instructions to remove the back of the tablet then disconnect the battery cable(careful not to damage the circuit board), reconnect the battery cable, and replace the back cover. Connect the charger, within a minute the screen on the tablet will pulse/flicker which is good news, allow it to charge a while, turn on the device, turn off the wireless wifi, click the power button to turn the screen dark again, and allow to charge for another 6 hours or till fully charged (when not connected to wifi the background processes will affect the charge time, on a weak charger it may not even charge like from an usb port on a computer).
Again, you should only be concerned with the video up to about the 1 minute and 15 second mark. You only need to disconnect the cable then reattach it. ONLY DO SO if you are comfortable doing so. If you have never worked on electronics before or are uncomfortable find someone to do it for you.
You maybe need different/extra codecs. Try download them in de app store, or try download a different video player. https://play.google.com/store/apps/details?id=com.moliplayer.android.libv6vfp
Try holding the main power button and the home button down until the unit shuts down. When the Apple logo appears, release both buttons. After it resets, check to make sure that the iOS is updated to the latest version. Hope this helps.
To make the Bluetooth connection, you turn on the Galaxy Tab's Bluetooth radio. Obey these directions:
On the Apps screen, open the Settings icon.
Choose Wireless & Networks.
Place a green check mark by the Bluetooth option.
When Bluetooth is on, the Bluetooth status icon appears. Here is a tutorial video on youtube: http://www.youtube.com/watch?v=ol5Vg-fpKDI&noredirect=1 If you wanna know more about Galaxy Tablet you can go to here: http://www.aneesoft.com/tutorials/tablet/index.html
Well my friend... You can just open up the frame that's in front off the screen and unplugg 2 video cables from the back of the screen and buy a new screen.It's more cheaper to do it self! This is a very good video on 'How to replace a notebook screen: http://www.youtube.com/watch?v=1eaI5aobwDU
