When switched on its just bleeping and on screen it just says err 2
This happen can be E1 OR E2 whatever because this change from some manufacture to another. This mean:
1) LUBE the deck belt,very well
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there ARE not, the board is faulty.
see the block. Try to run the sofware calibration after you fix,
God bless you
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
SOURCE: treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: Reebok REM 11300 have moved my treadmill, it has
I had the same problem, this is how you fix it.
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
