Dial making sound to find position and after pressing start the light of time left comes on and the door locked button flashes but the door is not locked and the cycle will not begin.
SOURCE: Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
SOURCE: Hoover washing machine front loader, has power,
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged
drain hose or the water pump. You’ll need to drain the water out of the
base and also check to see if there's something
stuck inside the pump or the drain hose connected to the pump (pump is usually
located at the bottom and towards the back of the washing machine). If the
drain line isn't clogged, you may have a problem with the water pump such as a
frozen pulley or a broken impeller. If that's the case replace the water pump. Please
do accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
SOURCE: cannot open door and lock light stays on
It has a timer circuit that locks the door with a selenoid. It has a sprig that pulls the safety latch back off of the latch. Either it isn't turning the power off or the spring is broken or too dirty with soap and wont work right. Try pulling the power and see if that works. If not got to take front cover off and check it out.
