Dishwashers Logo
John Higdon Posted on Jun 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bosch dishwasher she6af02uc is showing an E-24 error what is this
Mark
Level 2:
  • Expert 141 Answers
  • Posted on Jun 29, 2012
 Mark
Expert
Level 2:
Answers
141
Questions
0
Helped
50447
Points
325
Error code E24 = Drain hose blockage or pump impeller failure, suppose running it with filter unsecured would allow some goodies to get in there.
Changing the fine mesh filter should fix this.
5 Related Answers
Anonymous
  • 1036 Answers
  • Posted on May 02, 2010
SOURCE: latch is not working properly
It's possible the machine is slightly twisted.
Try re-levelling it to start.
You can usually tell when the door is not quite closed if it looks out-of-centre.
The next thing to check is lubrication of the catch. Try some WD-40 in the latch mechanism.
If still no better, then the latch may need adjusting by removing the front panel (unplug machine before doing this).
Grease the moving parts and adjust catch for easy closing.
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: My bosch dishwasher starts then stops with a error
I have had a few people with the same my advice is to tell the comp. you bought it from it is under warrenty
Anonymous
  • Posted on Sep 20, 2009
SOURCE: Error code E:24
bosch logixx error code: e24?
Anonymous
  • 8197 Answers
  • Posted on Oct 31, 2010
SOURCE: Bosch Dishwasher Model # SHE6AP05UC\r\nDoes not
An error 24 code on your Bosch dishwasher means that you have a clog or that your pump is bad. Check and clean out your airgap. If that doesn't work and your machine is still under warranty, call Bosch. Bosch won't tell you what the error code means, only that you need a service call, and they will then give you some phone numbers for Bosch authorized appliance repair places, one of which was Mr. Appliance. The appliance repair place will want to put in a new part whether you need it or not so that they can get paid by Bosch. I found this out the hard way. Hey Bosch, be smart and tell your customers what the error codes mean so that they are informed and you don't look like you are trying to rip them off. Leave that to Mr. Appliance. You can always remind the customer that working on the actual dishwasher voids the warranty.
Good Luck
Oloyede Monsuru
  • 1468 Answers
  • Posted on Dec 15, 2010
SOURCE: Bosch dishwasher has E 24
This means that the Dishwashers has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the beeping sound, then try turning the Dishwashers off and on again. If you still see the "E 24," turn off the power to your Dishwashers and wait five minutes before turning it on again. If you hear the beep or see the "E 24 " when you try to washing again, please call your authorized provider for service.
Hope this help?.
Thanks for visit.
2answers
EdgeStar DWP61ES turns itself on and off, display shows H:01 then counts up through H:24 then either turns off or starts the count again.
Many owners of the Bosch dishwashers perceive h01 (h: 01) or h02 (h: 02) and other signs as an error. But in fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then washing process will begin exactly in 2 hours. As a rule, in most models of dishwashers from Bosch, a delayed start can be set in the range from 1 to 24 hours.
Timer programming You can delay the start of the program in 1-hour steps up to 24 hours.
  1. Close the door.
  2. Switch on ON/OFF switch [1].
  3. Press button [4] + until the digital display [9] jumps to h:01
  4. Press [4] + or - button until the displayed time corresponds with your requirements.
  5. Press START button [6], timer programming is activated.
  6. To delete timer programming, press the [4] + or - button until h:00 is indicated on the digital display [9].
You can change your program selection at any time until the program starts.
FOR LINK https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-h01-h02/
Does it hurt to use bosch diswasher with error 24
https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-e24/
Bosch dishwasher error 24
Hi!
here are manuals to BOSCH dishwashers. Please kindly check if there is a manual to your device which helps you to solve the problem. https://manualsbrain.com/en/brands/bosch/dishwashers
WHAT DOES ERROR CODE H19 MEAN ON A BOSCH DISHWASHER AND HOW TO FIX IT PLEASE?
I think, this is not an error. The user manual describes how to show the error codes (see picture below). I suppose it comes to delay the start of the program in 1-hour steps up to 24 hours and is indicated by a lowercase "h:1" - "h:24". Also, it is used a capital letter "H:07" when adjusting regeneration depend of the water hardness, but water hardnes is between H:0 - H:7 (so it is impossible H:19).
25896707-o1c1srjpvjfad2vccu212vzy-4-5.gif Dado
1helpful
Bosch dishwasher model she6af02uc/03 odor
try running some bleach in the wash cycle
I have bosch she6af02uc,just installed, turned on, E-23. no operation at all, turned off drying agent, still nothing
CHECK WIRE OFF ON WATER VALVE OR FLOAT SWITCH THE DW IS NOT GETTING WATER. FILL BY HAND AND SEE IF IT RUNS
Dec 03, 2010 • Dishwashers
26helpful
2answers
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
