Good luck with that, if you want to unlock your phone, you can use the service on the following page: http://www.fastgsm.com/en/samsung/samsung/a667/network-unlocker/network-unlock
SOURCE: how to unlock sgh-a737
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: imei
Dial *#7370# and set the default settings. This may cancel your previous action. And dont go on experimenting with unauthorised codes. they could be very dangerous to the phone, as you have seen already.
SOURCE: NEED SUBSIDY UNLOCK CODE
I work at a T-mobile corporate store the only way to get that information is to go into the store with the account holder because they need to verify ID and then they will give you the number for the unlock department. Tell them you are going overseas and they will email you the code.
SOURCE: FREE samsung sgh-t239 sim subsidt unlock code
Whats the code required to unlock the samsung SGH-T239 Phone IME # 011841 00 030683/101
