Since the last software update from tomtom the computer voices on my tomtom keep breaking up.I sent a email to tomtom about this regarding this problem,they told me to format the tomtom this I did and I can now not get the computers voices on my tomtom to work.
They computer voice is showing on my tomtom via my computer as a file but it is not showing on the change voice screen on my tomtom can any one help with this problem.
On your device you may have a corrupt file that is causing the noise distortion when you use the computer voices. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder. DO NOT copy the 'Loquendo' folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
STEP 6. Install a computer voice
• Open TomTom Home
• Click on 'Add maps, traffic and voices -> computer voices
• select the voice of Kate and install it.
The Computer voice is now installed, and your TomTom should now be working.
I had the same problem and the cause was accidentally having downloaded some voices and app files onto the memory stick. Delete the memory stick contents and all of a sudden it worked perfectly
Hi, I have exactly the same problem and it's so frustrating! I followed TomTom's advice and re-formatted, but sadly without success. I have tried to re-install the computer voices, and although they show up on the pc as being installed on the device, it doesn't show up as an option on the device itself. Yet i recently installed 'John Cleese' - no problem at all. Anyone got any other ideas?
I had the same problem but had to use onother computer to update my 720 as some of the Home software on the PC appeared to be corrupting the install; I used all the same process as suggest just on a differnt PC.
