I need to buy a new front wheel as mine has gone like a bad shopping trolley, and assume the ones you buy now will fit onto the older model? Also, one of the bolts in the side has come out and been lost so I need to find one and have this put in.
Hi
The initial reaction for the front wheel issue would be that a build up of dirt and grime is causing it to misperform. We would recommend a thorough cleaning of the front wheel unit with furniture polish or dry teflon spray (found in the laundry aisle of larger supermarkets)
You can also book in the chassis for inspection / repair work required on 01284 413 141 Mon-Fri 8.30-4.30 (Excluding Bank Holidays) Also to obtain replacement central hinge screws you can contact this number and we will be happy to assist.
SOURCE: spare tyre/wheel
You don't need a whole wheel, inner tubes are available at most cycle shops - it is the same size as used on the small bikes for kids (12 1/2 x 1.75 x 2 1/4) - they cost around £4.50 and if you're not sure how to fit it, then they could probably do that as well.
SOURCE: front wheels on quinny buzz are a nighmare....
http://www.babycare.nl/quinny-buzz-all-terrain-front-wheel-p-1819.html?language=en&name=Quinny%20Buzz%20All%20Terrain%20Front%20Wheel
SOURCE: front wheel conversion
Hi Nathan,
Please have a look here:
Buzz 4 front wheel
and alternatively the
Buzz All Terrain Wheels
International shipping is available.
Hope this helps.
With kind regards,
Babycare.nl
Erwin de Raad
SOURCE: problem with the front wheel Quinny buzz 3
This does sound like you have got a build up of dirt within the wheel assembly unit. I would suggest that you remove the entire wheel (push the two black buttons either side of the axle and pull) then clean the entire wheel in warm water. Lubricate the moving parts with a thick lubricant (something like vaseline, not DW40 as this attracts dust) then pop it back on, that should sort it out.
If the wheel is still not working, then contact your retailier if still within warranty (two years chassis and one year fabrics). If this is out of warranty, contact www.quinny.com who will be able to sell you a replacement wheel assembly.
I hope this helps.
Testimonial: "Thanks for your help, he will is much better"
