Washing Machines Logo
Posted on Dec 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer acting crazy
Washer is a front loader and it is making all kinds of noise when it is on spin. any ideas on what to do?
Anonymous
Level 2:
  • Expert 179 Answers
  • Posted on Dec 20, 2008
Anonymous
Expert
Level 2:
Answers
179
Questions
0
Helped
49471
Points
446
You have bad bearings or a broken basket basically, your washer needs to be rebuilt it will be cheaper to buy a new washer
We just bought a used Frigidaire front loader bought in 2004 and the washer jumps when in even the lowest spin cycle. We have bought a rug for under the washer and it has not helped. Any ideas???
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Why is my front loader making noise as it spins?
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
My front loader is making noise as it spins
Hi,,
heatman101
1helpful
Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
2helpful
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
2answers
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
Loud banging during spin cycle
please balance your washer and use smaller loads
3answers
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
