After the using facebook could not update so I tried restarting it &then this happenAfter the using facebook could not update so I tried restarting it &then this happen
Question edited for clarity and toss in a load of CAPS.
Disconnect the element and the fan and check them both for continuity with a multimeter. If the circular element or the fan fails, nothing works, so it could be either.
If you're using adblocking software, turn it off or make sure that Facebook is included as an exception. Try uploading the original photo instead of an edited version. Editingphotos (example: with iPhoto or Photoshop) before uploading them may cause theupload to fail. Check the photo format.
I would try to uninstall the Facebook App, and then restart see (* below) the iPad mini, and after that re-install the Facebook App.
* You should do a full re-start of the iPad. This means holding down the on/off button at the top edge, while holding down the "Home' button for at last 5 seconds, or until you see the "Apple' logo appear on the screen.
Good luck
Try restarting it: hold power button down until "slide to power off", power off for 10 seconds, press power to restart.
if that doesn't fix it, reset your iPad: hold BOTH power button and Home button until device resets and apple logo appears.
How to hard reset:
Warning! All data will be lost!
1.Power off your phone
2.Press together volume up + volume down + power button until recovery menu appears
3.Select "recovery" with volume buttons and press camera button to confirm
4.Press home button when Android logo appears
5.Select "wipe data" with volume buttons and press camera button to confirm
6.Select "yes" and press camera button to confirm
7.Wait until format ends
8.Select "reboot" and press camera button to confirm
9.Wait until phone restarts
That's it!
- See more at: http://factory-reset.blogspot.com/2013/09/motorola-defy-mini-xt321-hard-reset.html#sthash.eUfAgbLd.dpuf
had a similar problem over the last couple of weeks which culminated in the Blue Screen of ***** and hard drive FAIL. Cost 120 euros to replace on a Hewlett Packard laptop. Sorry. :(
you will need the restore cdrom's to fix this issue. sounds like you the wrong upates! you should only updates that come from the sony web site for your particular sony item. refer to sony tech support.
if it is an iPod touch, Hold down the sleep button and the home button together until the screen flickers and you then see an apple logo. If it is an iPod classic ,nano (except the latest), mini, hold down the select and play button together until the screen flickers and you see an apple logo.
After restarting apart from m logo comes on screen
What is the solution to the problem & how do I rectify it
Why m logo sign does not go away
Does not start
