Replace the trancefer roller or hvt power supply board
If your m\c show err code 000064-0000 d PCR or PTR is faulty first cange d pcr (pre charging roller)m\c is wrking well if not working change PTR(pre transfer roller) then m\c is working.
Did you try to think about replacing DC Controller (FG3-1998-020) i
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
