Question about LG WM-2277HW Front Load Washer
My lg washer appears to be leaking from the soap tray area, what needs to be replaced and how?
I took off the front of the washing machine, cleaned the gasket and tightened a loose bolt and removed/cleaned residual soap from the soap tray area, and then put everything back together. All front leaks are gone, but the internal leak that took place during the rinse cycle (after about 30 minutes on a normal cycle is still there. Help! How can this mess be fixed?
  • 1,360 Answers
The hose from the soap drawer to the tub may be split. These hose have flexible ridges and its common for them to split inside one of the ridges.
Posted on Sep 17, 2017
6ya staff
SOURCE:
Anonymous
  • 236 Answers
SOURCE: leaking washing machine
you need to clean above where the drawer goes in, the water jet holes get blocked and spray sidewards. also you can reduce the water pressure at the supply tap to a fast trickle this will avoid jets of water flowing over and forward of the tray.
Posted on Jun 23, 2007
Anonymous
  • 3 Answers
SOURCE: lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Posted on Feb 10, 2008
Anonymous
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
Here is the answer !!! My LG front loader has leaked once a year for the past 4 years. The rubber bellows (a part underneath the washer) cracks and causes the leak. DO NOT LET THEM TELL YOU THAT YOU ARE USING TOO MUCH DETERGENT ... THAT JUST AN EXCUSE !!! The part costs around $12. Here's the link ...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?R=1514&searchText=LG%20Washer
Posted on Oct 06, 2008
Anonymous
  • 15 Answers
SOURCE: LG WM2487 Leak Front Left
Not sure if this machine is similar to the WM2277, but here is the procedure for that - my leak was in the "baffels" hose that connects the drum to the drain pump:
1. Drain the machine - pry the panel at the front left lower corner to get access to a stoppered tube. drain as much water from here as possible.
2. Remove screw visible inside this area and remove the white molded plastic - also remove the screw behind that plastic.
3. Open the washer door and remove the spring loaded wire around the door gasket. Carefully pull the door gasket away from the panel push inside and then reclose the door.
4. Remove the detergent drawer and the two screws visible behind it.
5. Pull the top of the electronics panel away from the machine and lift up - place on top of machine or hook it out of the way
6 Remove the 4 screws that are visible holding the front panel to the machine. Left the entire front panel up about 2 inches and swing to the right (there is a wire connecting the door to the machine on the right)
Posted on Apr 27, 2009
Anonymous
SOURCE: LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Posted on Dec 19, 2009
M y Bosch WFX 3250 washing maschine spill water over the top of the soap tray and out on the floor. What to do?
Remove the soap drawer completely. They usually pull straight out after overcoming some resistance at the end of the normal travel.
The problem you have is usually caused by a buildup of soap residue blocking one of the drains from the soap compartment to the wash tub. Clean all traces of residue from the drawer and the inside of the compartment and then pour water into the drain(s) to check for blockage(s).
Sometimes the top panel of the machine must be removed to access the hose(s), for removal and rodding through but often it is possible to clear them from the soap compartment using something flexible of a suitable size.
Jul 18, 2016 | Bosch Washing Machines
How to fix leak from soap dispensor
I assume you have water coming out of the dispenser and running down the front of the machine. You probably have a build up of soap powder in the water inlet and it is restricting the flow and backing up.
Soap powder is only partially soluble in cold water and a residue of undissolved powder builds up over time, one of the reasons I use a liquid detergent. Remove the dispenser tray, it should pull out fairly easily with just a little resistance. Try and clear any blockages, hot water is best as it dissolves better. Clean the tray you have removed and re-assemble.
Dec 07, 2015 | Maytag MAH6700AWW Neptune Front-Load...
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Water leaking during wash cycle
I've had this problem and immediately assumed it was the door gasket. However I actually sat & watched it for a whole cycle & discovered that water was running back out from the soap dispenser area and dripping from the bottom of the washer door. I removed the dispenser tray & discovered an inch of built-up soap had accumulated inside the washer, which was not allowing the water to drain through properly. Once I removed the soap & residue, problem solved.
Jul 30, 2010 | Washing Machines
My washer is leaking detergent from the tray on the front of the washer. I cannot find anything online to help.
YOU MEAN THE TRAY WHERE YOU PUT DETERGENT, BLEACH, AND FABRIC SOFTENER IN? IF SO, REMOVE THE TRAY OUT COMPLETELY. REACH INSIDE MAKE SURE THERE IS NOTHING IN THERE THAT COULD BLOCK THE WATER GOING INTO THE MACHINE VIA A HOSE. AND ALSO CHECK AND CLEAN YOUR TRAY. THE TRAY CAN BE DIS-ASSEMBLED TO CLEAN. RUN IN WARM WATER AND MAKE SURE YOU CLEAN THE WHOLE THING OF SOAP AND SOFTENER RESIDUE. DON'T FORGET THOSE TINY LITTLE HOLES ON THE TRAY AND THE REMOVABLE CAPS
BOYNISMO@YAHOO.COM OR 714-334-1998
Dec 09, 2009 | LG WM1812C Front Load Washer
How do you get rid of the musty smell in a front load washer.
38c7a1e.jpg MNTECH
Rank: Guru
Rating: 93%, 650 votes
Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
Soap dispenser keeps filling with water after everyload. I have to empty after load. The dispenser is also growing mold.
You should clean the soap dispenser regularly by removing it from the washer.
Some units have a release clip but some just need to be pulled out firmly by hand.
Then give the tray a very good clean as no soap residue should be present. It sounds like the fabric conditioner cycle is filling the relevant tray section but unable to drain through blockage.
Should be pretty straight forward to remedy.
My regards
Marc
Apr 17, 2009 | Frigidaire GLTF2940ES Front Load Washer
He4t dispenser problem soap
Remove the soap tray and clean the orifice.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Water pouring out from soap tray !!!
hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Sep 13, 2008 | Washing Machines
Lg wm1812cw front load washer
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
2,707 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
