ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO COMPUTER
If your photos and videos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
SOURCE: Transferring pictures
you can go to your control panel and go to "add new hardware" icon. them you can search for plug-and-play devices such as youe camera
SOURCE: not able to watch video shoots on my PC (windows XP 2000) after transferring from camera
The problem is exactly as described in the message. Windows media player will not playback files of the type .MOV unless you revert back to WMP version 6.4 (current version is WMP 11) and then install the appropriate codec which is available on this link; http://www.free-codecs.com/download/QuickTime_Alternative.htm Much easier and better way to play back files of this type you need different player software - the best being "Quicktime" which you can download for free from this link; http://www.apple.com/quicktime/download/win.html If you want a user manual for your camera go to this link; http://www.retrevo.com/search?q=Nikon+L3&terms=review+manual and click where it says "download pdf" I hope this helps, please ask again if you need any help with installing quicktime, enjoy your movies :)
SOURCE: nikon s51 can't transfer video from camera to comptuer
Try removing the memory card and insert it into a USB card reader and connect it to the computer to read/copy the images/video files.
You should format your memory card using the camera functions before you take the next lot of pictures and videos.
Make sure you have the drivers installed for your camera. If the computer can't detect it, then thats the reason. You should be able to find the drivers on Nikon's website. Good luck.
How are you trying to make them communicate, are you using a USB?
If so make sure you select the proper action when your PC prompts you. Transferring and playing are two distinct things, that is to say, sometimes you may be able to transfer a file to something but, that file may not play due to compatibility.
