If you plug the machine in the off light is green and it falshes a red light 2 times
The blinking of 2 red lights on a Scotsman ice machine CME256WS typically indicates an error code. The most common cause of this error code is low water pressure or a problem with the water supply. You should check the water pressure by using a gauge on the incoming water line. The pressure should be between 20 and 120 psi. If the water pressure is adequate, you may have a problem with the water inlet valve, which is responsible for letting water into the ice maker. If that is the case, you may need to replace the valve. You can also check for clogs in the water filter or water supply line, and ensure that the water shut-off valve is open. If all the above steps are done and the problem persists, It is recommended to call a qualified technician to inspect the machine and diagnose the issue.
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
