Question about Toshiba E-studio 2330c 2830c Color Multifunction Copier
Toshiba 233 misfeed in finisher - Toshiba E-studio 2330c 2830c Color Multifunction Copier
4 Suggested Answers
6ya staff
SOURCE:
checkitright
CheckitRight
  • 1363 Answers
SOURCE: misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Posted on Oct 20, 2008
MIAN
  • 87 Answers
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Posted on Dec 16, 2008
Anonymous
  • 59 Answers
SOURCE: toshiba estudio 550 copier misfeed to finisher
hi just cheq the pathe of finisher or path sensor of finisher
thanks
Posted on May 15, 2010
Toshiba e 233 is error code E550 what problem sir
Code E550 Description Paper remaining jam on the transport path: The paper is remaining on the transport path when printing is finished.
Jul 28, 2015 | Toshiba Office Equipment & Supplies
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
Bios damaged!
Le programme pour le BIOS est ici:
http://support.toshiba.ca/support/Download/ln_byModel.asp
Vous pouvez trouver votre ordinateur portable dans le menu et télécharger les utilités de BIOS de là.
Ceci a été traduit avec le bablefish et le Français est ma deuxième langue, ainsi je suis désolé au sujet de toutes les erreurs.
Jan 25, 2010 | Toshiba Tecra 8100 Notebook
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
Misfeed in finisher
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
Misfeed in finisher
Oct 19, 2008 | Toshiba e-Studio 232 Black and White...
Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Sep 16, 2007 | Sharp AR-M455N Copier
Toshiba E-studio 2330c 2830c Color Multifunction Copier Logo
67 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
