A
Anonymous Posted on Jul 02, 2012
I want to print in black only with Lexmark X544. The color toners are not empty. Is there any easy way to change the print setting to black ink only?
5 Related Answers
Anonymous
  • 2985 Answers
  • Posted on Aug 30, 2008
SOURCE: How to print with black ink only when color is empty
Correct - the same for most InkJets- Full complement of cartridges
re uired -- Many years ago some basic Z series Lexmarks had colour/black swappable casrtridges- but that is long gone.
Anonymous
  • Posted on Oct 06, 2008
SOURCE: Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Anonymous
  • 3 Answers
  • Posted on Mar 29, 2009
SOURCE: cant print in black when color toner is out.
Turn of the printer and remove each color toner cartridge and shake it good before putting it back in place, Turn it back on and then it should work. Also you might need to reset your toner cartridges. I found that information at UNI-KIT (toner refill people, reset the counter (Reset Gear)). I just refilled one and found out the hard way that there was a lot of toner left in the cartridge. Also I found that by turning the power on and off that will make it print for a while.
Anonymous
  • 103 Answers
  • Posted on Jan 26, 2010
SOURCE: can i print using black ink when im out of color
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Anonymous
  • 415 Answers
  • Posted on Feb 11, 2010
SOURCE: I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
How do I open the lexmark x544 to change the cartridges
you could start on page 168 of the manual. I don't like to type everything there. In the end you still have to read it.
Use a PDF reader like adobe acrobat reader (free on the net) to read this:
http://www.lexmark.com/publications/pdfs/2007/x54x/v5404678_en.pdf
Lexmark X544 standard bin is full
In output between rollers you have a plastic parts wich moves. They are the output bin sensor. Maybe are stuck, see if moves.
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
1helpful
2answers
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
4helpful
2answers
Cannot print in black because color cartidge is out of ink
There is a 'low toner' override in the menu system, but if this has NOT been set already, a 'flag' will be set on the chip on the cartridges that are low/empty.
The printer needs to 'see' cartridges that are usable, i.e. NOT empty, in order to function.
It is possible to replace just the chips on the colour cartridges, but then any colour printing quality could be compromised of course, as the colours will be low/empty. You would then be able to use the printer as if it were a mono laser, just changing the black cartridge when needed
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
6helpful
2answers
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
1helpful
Lexmark 125 Prints Labels with color cartridge
I kicked the **** out of it and it started to print. I don't recommend it if you are afraid you may damage the electronics. The way I saw I spent damn near 70 dollars on some useless print cartidges nothing was wrong with them. The error message kept saying ADD CARTRIDGES. Anyway I'm thinking about a new printer anyhow.
1helpful
2answers
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
