maybe the hose came off the water level switch,,,just remove the screws in each end of the control panel,,some machines you have to remove the panel end caps to get to the screws,,,,then pull slightly forward and flip the panel back to access the level switch,,,,,,my hose came off 1 time and flooded the kitchen lol,,,,but air pressure coming through the clear plastic hose kicks off the water coming in and allows the timer to move forward to next cycle!
maytag has had multiple problems with the neptune series (atlantis included) units. Test the pressure switch for function and continuity, and also make sure pressure switch tubing is free and clear of obstruction or pinching. Replace pressure switch or tubing if needed. Pressure control may be located in machine control board on some models, if this is the case and the tubing is checking good, replace the machine control, not the interface or motor control board, and then test. all should be checking ok.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
