Our freezer has a drip that ends up in the bottom of the freezer pan and runs onto the floor when it fill up. It's a new puddle every 2 days and it's ruining my hardwood floor.
there's no drain there, and there shouldn't be a drip to begin with.... Our freezer has a drip that ends up in the bottom of the freezer pan and runs onto the floor when it fill up. It's a new puddle every 2 days and it's ruining my hardwood floor.
You can't post conmments that contain an email address.
Guys, . . . small puddle of water on the FRONT left side?? Y'know, . . under the FREEZER door??!? Maybe check the John Guest quick connect/disconnect fitting at the bottom of the freezer door just behind the front cover. It may not be fully connected, or may have a seal worn-out.
Sounds like a poor install. If the hoses aren't collected correctly heat from water could cause expansion therefore looser doors and hinges. Make sure the water connections are tight and then check the screws at the bottom of the door. you shouldn't need a pro to fix.
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water)
Make sure water drains when you
pour it in. If it doesn't - also clean drain tube on the back of the
unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
I have been selling and been doing factory authorized service on GE for nearly 30 years. I have sold many of this model. It's hard to imaging that a machine would leak water on small loads but not larger loads. In a case such as this, a servicer must remember to test the machine exactly as the home owner is using it. I would take pull the machine away from the wall and adjacent cabinets and dryer if hoses permit, (so that I could rule out water coming from somewhere other that the washer) remove the front panel, and have the home owner run the exact cycle with the exact settings and the same clothes load and soap used when the machine leaked. I suspect that some water is splashing over the wash tub. If you use a gentle cycle or a larger load you get less splashing. Even having a few more cloths items in the machine would reduce splashing. You might not expect a solution, but you do deserve an explanation. Some times the solution is strange, for example: I had a customer who said the washer leaked a lot of water onto the floor the first time it was used in the day, but worked great the rest of the day. I came out early the next day and tested the machine, and it did exactly that. What happened was the builder added on this new laundry room and the drain pipe went through the floor before the plumber added the trap. The builder then insulated the area but put the insulation on the room side of the trap, allowing cold air to freeze and plug the drain. After warm water pumped into the drain and most of the water overflowed the top of the pipe onto the floor, the rest of the water melted the ice in the trap and the machine worked fine until the next day after the water had a chance to form a later of ice in the trap again. The fix was simply to move the insulation to the other side of the trap. (OK, here in Minnesota we run into weird things like that, but my point is to test the machine exactly as it is used to find where the problem lies) I'd like you to post a comment when you find your solution.
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
