Error s5
SOURCE: Samsung microwave shows. Error code S5 how do I fix this what. Part do I need?
Having no more info that has been provided I'd suggest to buy a new one
Ok so I came across the dreaded s5 error on my venmar jazz a overpriced and poorly built microwave that had broken down 2 times already and was only covered for one circuit board failure when it happened twice so no warrenty on it and the error pops up I found links to videos explaining the contacts get covered with cooking oils and such and if you take the board apart and clean everything up its all good , been there done that the microwave did work for a month I'll admit but now it's down for the count no amount of cleaning made it better
So I started thinking of the time my Samsung tv kept turning on then off and not back on again, that turned out to be a few 60 cent capacitors . Sure enough I looked at the circuit board connected to the back side of the key pad and seen one of the caps had a very slight budge the larger of the two , so went out bought a better quality replacement for 65 cents and replaced it .its been 4 weeks and still no problems with the microwave.
Hope this helps out someone in the same boat .
Cheers and best of luck!
