Intermec CN70 Handheld Mobile Computer CN70AQ1KN00W1100 Barcode Scanner Logo
Mohammad Posted on Jul 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scanner setting i want the scanner to suffix enter code (13) after each scan , how i can do that?
Anonymous
Level 2:
Novelist:
  • Expert 75 Answers
  • Posted on Jul 26, 2012
Anonymous
Expert
Level 2:
Novelist:
Answers
75
Questions
0
Helped
154926
Points
149
Got to the following:-
Start >> Settings >> System >> Intermec Settings
You are then presented with all the settings you can change within teh device. From here got to:-
Data Collection >> Internal Scanner >> Symbology Options >> Postable
You are then presented with an input field. Enter your (13) here and hit [OK] to save and exit.
Use notepad on the device to check that the 13 is placed at the end of the {Barcode Date}
I confirmed this on a terminal we have here and it worked 500011972829613
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
1helpful
2answers
4helpful
2answers
How do i get my scanner to do "enter" without
Hello Severiano,
this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document. https://docs.symbol.com/attachments/ADC-01244.doc
2answers
After scanning a bar code I need it to enter and go to next row in excel
This can be possible, therefore it is not an Excel setting. You would need
to use the software that comes with your bar-code reader to configure this.
Try looking in your bar-code reader documentation for "Append Enter" or
"Append Carriage Return"
I'm using Symbol LS1004 with SirsiDynix Symphony 3.3.1 Workflows. How can I tab over after each scan, without having to hit <Enter>? Thanks, -john
Here is what I did to fix the problem of the bar-code scanner not going to next line after a successful scan. (Symbol ls4000i,This fix should work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning! If you set scanner to default, you need to be aware of which bar-code types you use. (We use UPC-A) Also if you have it programed for other things already you may not want to set all settings to default. You can skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5. The Suffix you want to add to fix this particular problem is ENTER. So that it goes to the next line. There is a prefix/suffix value chart on page 162 table A-4. The code for ENTER Is 7013. In order to enter this code you will need to print off the Numeric Bar Codes found in section 5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your scanner should be working now. Also look through the manual there are some nice functions that can be turned on and off with a simple bar code scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
Need to add prefix ~ and suffix / for ls2208. I have no problems programming other brands, but symbol has me stumped. The code for ~ is 1126 right? So I tried scanning the 'scan prefix' barcode, then scan...
Have a read through this document.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
look at 13-4
have you tried scanneing the enter barcode after 6 ?
1helpful
2answers
Hi, i am trying to configure my barcode scanner LS2208 to put a {TAB} in when scanning
There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
1helpful
I have a Symbol LS3070 that has stopped sending a return after UPC-A scans. I added a suffix of 7013, and got no change. Any Ideas?
Scanning Scan Options, Data Suffix, Enter from Adobe pages 141 and 142 of 214 the LS3070 Product Reference Guide resolves this issue. The suffix is already set to 7013 so scanning the barcodes above should be all you should have to do to send the return or enter key after every barcode scanned..
3helpful
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
I need three characters in suffix on LS2208
so you need it to be 0AH + 03H + 03H/BARCODE/PRESS ENTER definetly try adf rules
4helpful
2answers
Problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Top Intermec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
