The info you need is in the owners manual, if you don't have one you can download one at the Toyota owners site, you must however register your vehicle, it is free.
http://www.toyota.com/owners/web/pages/home
SOURCE: NEEED FUSE FUSE BOX LAYOUT FOR 2003 DODGE GRAND CARAVAN
You can get free owners manuals online at:
http://www.edmunds.com/ownership/howto/articles/120189/article.html
or just type "owners manuals" in your search.
Here is a post I found that worked for my 2005 caravan.
For a
2001 Dodge Caravan: The owner's manual is vague, only stating that all
fuses are under the hood in the fuse box, no diagrams. Once you have
removed the fusebox cover, the diagrams for what each fuse does is
provided under the lid. UNCLEARLY marked is the radio fuse, a 20amp
fuse located 2nd row from top to the right of the accessory relay. It
is marked: RDO/IP IGN.
Jake
SOURCE: Fuse box layout for a 2002 VW Cabrio
Fuse colors
30 A-green25 A-white20 A-yellow15 A-blue10 A-red7,5 A-brown5 A-beige3 A-violetFuse locations
Fuse Location
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1-Headlight, Low Beam, Left (56b)102-Headlight, Low Beam, Right (56b)103-License Plate Lights (58) 104-Rear Window Wiper And Washer System155-Windshield Wiper/Washer156-Fresh Air Blower, A/C (X)207-Tail Lights, Right (58R)108-Tail Lights, Left (58L)109-Rear Window Defogger2010-Fog Lights1511-Headlight, High Beam, Left (56a)1012-Headlight, High Beam, Right (56a)1013-Horn (15)1014-Back-Up Lights1015-Engine Electronics (15)1016-Power Sunroof, Front Map/Reading Light1517-Emergency Flashers (15)1018-Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module2019-Coolant Fan, A/C Relay (30)3020-Brake Lights (30)1021-Interior Lights, Clock, Luggage Compartment Light (30)1522-Cigarette Lighter, Radio, Luggage Compartment Release10Separate Fuses
(Located above the relays)
-Fuse for ABS hydraulic pump relay30-Fuse for ABS main relay30-Fuse for A/C30-Fuse for power windows20-Fuse for cruise control5-Fuse for cigarette lighter15In the engine compartment above the brake booster:
-Glow plugs50
SOURCE: 1997 Honda Accord Diagram for 97 honda accord fuse boxes
I NEED A DIAGRAM LAYOUT OF MY 97 HONDA ACCORD FUSE PANNEL THATS UNDER THE DASHBORD DRIVER SIDE
