Last week when my friend bought a Windows XP installed netbook, he created a complex Windows login password to bolster the privacy of his netbook. Unfortunately, he couldn't remember the spelling of his own password the next day and was unable to use his netbook. I suggested Windows Password Key 8.0 to reset the password and start using his netbook again. Let’s find out more about Windows Password Key 8.0. Windows Password Key 8.0 is a useful application, which can be used to reset the Windows login password on your netbook with the help of USB flash drive. Windows Password Key 8.0 is compatible with all versions of Windows.
However, your netbook must have minimum system requirements to enable Windows Password Key 8.0to reset your Windows login password. First, your Windows must be installed in a FAT-16, FAT-32 or NTFS partition and you must also have bootable USB flash drive to reset the password.
You'll need to install Windows Password Key 8.0 on any other Windows PC, which is accesible to you. Once the installation is complete, Windows Password Key 8.0 will launch on the screen. In the Windows Password Key 8.0 window, you'll need to select the existing Windows Password Key 8.0 image, which is ideally located as a default option under ‘Choose the existing windows password key 8.0’.
Select the option ‘USB Flash Drive’ and insert your USB flash drive in the USB port. After you insert the USB flash drive, select it from the drop down list and click the ‘Burn’ button.
When the ‘burning’ process starts, Windows Password Key 8.0 extracts the ISO image and copies the necessary Windows files to your USB flash drive.
Now you can insert your newly created USB flash drive into your netbook port, and then reboot your operating system. Be sure to change your netbook set up to make it boot from your USB flash drive.
When your operating system boots from your USB flash drive, the Windows Password Key 8.0 will initialize on your netbook screen. You need to select ‘Windows installation to be processed’ and then select the user, whose password you need to reset by typing the number associated with it, followed by the ‘ENTER’ key.
In the next screen, type ‘Y’ followed by ‘ENTER’ to reset a new password. After you reset a new password, remove the Windows Password Key 8.0 bootable USB flash drive and restart your netbook to log in using your new password. It is always a good practice to set up a simple password for our windows login. Although we have utility applications like Windows Password Key 8.0 for our rescue, it becomes a tedious task to reset password, especially when you are travelling with important documents on your netbook.
If you forgot your Bios password then open the pc and reset the COS jumper.
If forgot your Windows password then restart your computer press F8 . select Safe Mode and try administrative login to reset password.
If you forgot the administrator password then use any third party software like Hirenboot to recover it.
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
To reset the Administrator user, you need to right click your My Computer and choose "Manage". The Computer Management window will open. Expand the Local Users and Groups from the left panel and click Users. Right click the Administrator user shown on the right and click Set Password. Click OK. That's it!
