SOURCE: Quinny Buzz Handlebar
I have the same problem too! To remove the handlebar set it to its longest position, then shorten it by 1-2cm. You will find that the plastic locking pin that you described is just a pair of lugs. With the handle bar in the above position you can then push both lugs in similtaneously while at the same time levering the plastic part out of the tube. when both sides are released the complete handlebar can be removed. From there it's fairly straightforward to strip down.
My problem now is that I can't find anywhere to get the parts from.
Any joy yet?
SOURCE: quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
SOURCE: hi, quinny zapp
Here is the US distributor of parts for all Quinny Strollers...
Dorel Juvenile Group USA
Canton Commerce Centre
45 Dan Road
Canton, Massachusetts, USA02021
(781) 364-3100
(800) 544-1108
SOURCE: replacement foam for quinny buzz handlebar
Hello
I am making handle bar, bumper bar and frame
covers for the bugaboo and can probably help you
with a cover. Contact me at www.bbsprouts.com
Diane
SOURCE: Removing telescopic handle of Quinny Buzz?
Pull the handle up almost all the way, the plastic pieces that hold the handle in place come out by pusining in the little black plastic dot but the handle has to be in the correct position. Move the handle up and down till you can easily push in the dot. The handle should then come off easily enough
