SOURCE: Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
SOURCE: Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
SOURCE: Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
SOURCE: maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
